OT: IP Rated DC Current Switch w/ Dry Contact
Snyd1
Jun 2018
there
225
Off topic, but you people here usually have pretty good suggestions.
Title kind of says it, anyone know of a DC current switch that has a decent IP rating for outdoors and dry contact output does not require a power supply? Looking to monitor/log when power is lost on a 72VDC power supply.
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
670
2,183
My turn to post a non-plc related question. Believe it or not, it's drive related. Most drive manufacturers specify the overload capacity of...
7,113
How do I get the mV or weight readings for individual load cells connected to summing board into the PLC? Do I use a MSG instruction and what are...
658
Hi all, I have an IDC from Rockwell, and it is super old, but new (had it in the spares). The previous one has gone faulty, and I need to set...
1,487
