OT - limit/lock from lift
_Woody_
Jan 2008
Auckland
119
Has anyone seen anything remotely like this? Apparently it is a door lock on a lift with some contacts to indicate to a control system. This is on a boat and may have been manufactured in Germany circa 1990.
Looking to source replacement or spares without having to re-engineer the whole thing.
Looks like a basic spring loaded limit switch.
Actually its kind of the opposite. It appears to be a mechanical lock / bolt with a set of notification contacts as to he position of the bolt. For the application I would expect the lift door to be closed and locked before the controls will allow the car to move.
I have seen something similar on a lift door
Check your local yellow pages for
Elevators Escalators Lifts
My suggestion would be Otis or Schindler as I think
they were the firm that did our annual maintenance
Yeah it is on a lift (on a boat) I am looking into the elevator companies as well but its proving to be difficult without a brand or part number. Thanks
Based on the probability it was manufactured in Germany, try 'http://www.kronenberg-gmbh.de'. They have many similar looking offerings, but the number of options available will make finding a match without a part number tricky.
Good luck!!
Brilliant - thanks for your help guys. I am pursuing the kronenberg switches that look to be very similar to the old unit. Did also find some Schmersal door locking devices but not quite the same.
Thanks again
Hi, I want to write a logic, I have total 6 analog input of temperature and have 1 drive. Now i want to start drive when any one of 6...
1,609
Dear forum members, By reffering to the blue labelled command on the attached file, Could you tell me what PLC register that is being limited by...
28
Good day: I am wondering if anyone has experience with the Kinetix 5500 S33 Fault. I have 3 drives in a group set as follows: 2198-H025-ERS2...
189
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
111
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
132
