OT....looking for a Proportional Valve
XtremeIN
Jun 2005
Indiana
217
Hello all,
As the title says I am looking for a Proportional Valve. We are using a Burkert type 6223 with a type 1094 controler. It MUST be Stainless or PVC, 4-20 mA input, 3/4".
Thanks,
Micheal
If you have any questions or need more information feel free to ask.....
Are you controlling Air, Oil, Water?
What pressure ranges are you working in?
What accuracy/repeatability/resolution do you need?
What frequency responce do you need?
1) Why isn't what you are using now satisfactory? The purpose of looking for else is . . . ?
2) typical inlet pressure?
3) how much pressure drop do you want the valve to take?
4) max flow rate?
5) medium temperature?
6) hazardous area? extreme operating environment?
7) actuator runs on air? electric?
Are you controlling Air, Oil, Water? Water
What pressure ranges are you working in? 125 PSI static, 40-50 PSI filling
What accuracy/repeatability/resolution do you need? unknown
What frequency responce do you need? unknown
1) Why isn't what you are using now satisfactory? The purpose of looking for else is . . . ? look for a less expensisve one, the Burkert works fine
2) typical inlet pressure? see above
4) max flow rate? as high as possible for a 3/4 valve
5) medium temperature? average 77, min 70, max 90
6) hazardous area? extreme operating environment? no
7) actuator runs on air? electric? electric
Any control valve in this size range and material would cost over 1K easily. Try Dwyer or McMaster catalogs. Can't say it is the best, but definately one of the cheapest. If no luck - just use Burkert.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
130
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
205
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
146
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
795
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
398
