OT.....measuring air usage
XtremeIN
Jun 2005
Indiana
217
Hello,
I am looking for a way to monitor air usage of a pnuematic spool valve. I am an avid paintball player and pretty good gun tech. I have been working on a few projects and one is increasing the efficiency of a marker without restricting flow. One of the hardest things to do is get a true measurment of efficiency. So, I thought if I could measure how much air was being used per shot I could calculate efficiency........ I have some PLC's, analog cards, and displays laying around and though I could impliment them into the process. Maybe some type of low flow flow meter????
Thanks,
Micheal
There are a couple ways to do it
1. Use air tank with known volume - pressurize - read pressure with a GOOD guage that is ACCURATE and has good resolution say .5 or .1 psi. Every time you trigger the device take before and after pressure readings and then use PVT = PVT to calculate volume.
2. Use a good ball type flow meter and record the readings. Connect to exhaust of your device. Make sure it never pressurizes so that you get good readings (pressure throws them off since they are cal'd to Standard Temp and Pressure). You can use a regular balloon to limit the pressure surges.
Dan Bentler
On site we have Yokogawa EJA110E differential pressure transmitter connected to process air line. I'm not sure if this can be used to measure air...
4,435
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,066
Hello everyone! Firstly I'd like to say that I'm new to this forum and also new to PLC programming world altogether, that said I really would...
27
4,856
I am looking for a way to determine level in a silo. The material is called Perilite which has a very light density. Bulk density could be...
2,753
In our water cooling tank, I've installed and successfully wired up 4 float switches & updated the PLC (big thanks to @parky for that). As a...
46
11,491
