OT Multi conductor reel?
geniusintraining
Jun 2005
SC
8,278
I have a project that I am trying to come up with a solution... the customer wants sensors on a manual moving ladder, the bottom rung and the handrails, I have found both that I can do it with but that causes a trip hazard as the ladder will have a multi conductor wire laying on the ground... has anyone seen some sort of hose reel that supports multi conductor wires? I know they have 120v that has 3 and maybe I can modify one of them but not looking to red neck this project
Mark
Maybe you can repurpose something like this: https://robot-reels.com/
We use them in my plant for teach pendants as intended, but it shouldn't be too hard to strip ends and make custom connectors?
What's wrong with going wireless
No matter what reel you use it will still have the cord
You could put the core overhead from the top of the ladder
No matter what reel system you use you will need a power winder that completes things as well as increase the cost
with a battery wireless system you have no cord to deal with
Cost and they are sticklers about any form of COM's, there are about 500 of them total so I am sure they would have an issue, they have a lot of wireless robots, I made them a RFID device and they specified that if had to be 13.56hz and could not be read over 50mm, but I like the idea of going overhead as there is a upper rail
I like them, thank you!
I remember seeing a few year back a laser communications system that would connect to moving equipment. It used raster type scanning so it could always 'see' the moving device. Sorry can't remember the name.
Thank you, that sounds way to expensive
I ask them for more pictures, I think I am going to try a reel at the top of the ladder and run the wires on the top support, the ladder only moves about 10ft so I was even thinking a cable with some loops to support it
I am finding allen bradley doesn't have a pre-wired terminal block and cable for the analog 1756 and 1769 modules unless you also use the...
5,859
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
290
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
142
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
555
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
517
