OT - Perpetual Motion HVAC?
If you live in an area with constant, reliable winds, a couple of large windows with a "funnel" collecting the wind and forcing it through the building could, in some strange way, be considered perpetual motion.
Is there some reference here that I'm missing? A quick googling didn't bring up anything.
IF you lived near water and could harness the power of waves? Then figure out a way to turn that power into a way that could circulate cooler air from the place you are generating the power?
Just my $0.02 lol
Ahh, much funnier with context. I suspected as such but wasn't sure.
But maybe they were trying to establish a gradient of cool to warm between the two units.
Sorry for not explaining what is depicted. It's what is commonly called a "mini-split", or "ductless" heat pump. Most can heat and cool, but the outdoor unit, which acts as a condenser for cooling or evaporator for heating, has to be outside.
It actually would work as a decent humidifier!
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
42
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
90
Bom dia, Estou com uma máquina parada algum tempo, meu servo funciona em modo manual, porém não funciona em automático. Meu equipamento e...
67
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
230
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
280
