OT Sourcing Push buttons
PeterH_DK
Jan 2006
Copenhagen
17
I posted a few questions some months ago converning recommendations about which PLC to buy. I got some very valuable answers and have been following various postings since. I have been quite overwhelmed by the amount of technical knowledge and the willingness to help. Thank you!
I decided on sourcing a TM100+ from Tri-plc, which I have a feeling nobody here uses. I chose this model because of the BASIC interface on top of Ladder and ready made communication facilities with a host PC via a modem. I could probably have achieved the same with other models, but this sems simple and straight forward.
Anyway I programmed the Plc - and spent quite some time debugging the code ;-) and the prototype seems to be working and ready for field testing.
But now I have run into a small sourcing problem.
I need some illuminated push buttons in 3 colors : Red, Yellow and Green. Preferably with a diameter of 40mm or 60 mm and the lighting is preferably to be 12V
I found some from Schneider /Telemecanique, but they are not available in DK and the price indicated to me was about 30 USD per piece, which is to expensive.
So the question is where can I source 40 or 60 mm illuminated Pushbuttons?
You are right there, most of us have not heard of this Company, however I think that it deserves some publicity here.
I looked at their web site. It appears that this is a Taiwanese
Company with US address. The product line is original and innovative. Specifically the VB programming and the PLC emulator
software. I may actually consider this PLC for some production monitoring jobs, the Excel spread sheet communication software looks real useful. I would like to know if anyone else has used this PLC and what they think about it?
Can anyone post any real life apps using this PLC?
For the record I have no affiliation with this Company and I will
always stick with the AB PLC's for major projects but like I said this PLC may be useful for some specialty apps and certainly for OEM's.
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,873
Good morning all. I have never seen this done but I want to ask if it is possible. On an AB 1766-L32BWA, can you have some of the inputs wired as...
2,381
I have a client who has installed a control system which was designed offshore (ASIA), and uses a power system common to the Asian market. The DC...
1,939
Hi there, I have a 2 wire npn sensor. For example in this diagram: I'm guessing i should connect it to a PLC dc sourcing input as such? Would...
5,267
Hello again guys, I've read tons of informations on sinking and sourcing inputs and outputs, however there is something bugging me with this. I...
4,392
