OT - Vacuum Valves [Chemical resistant]
chavak
Jul 2002
750
Off Topic - any info on solenoid valves to switch vacuum which used to suck away a mixture chemical solvents. We tried normal Festo and SMC solenoid valves, lasted only for 2~3 hours. I guess the seals in those valves degraded over time.
When dealing with vapors you need to check a chemical compatibility chart. Most valve manufacturers will have one or make recommendations for whatever solvent / vapor you are handling. This gets real complex when dealing with mixtures - the charts are NOT setup for this - talk with the factory.
If worse comes to worst you can use refrigeration to provide a freeze trap and condense the vapors. Will take careful temperature control to only condense but NOT freeze them.
Dan Bentler
Hi Everybody,
Thankyou for the links, the chemical is a mixture of ethonol and something tetro..... [I can't recall the name]. It is used to bond some tube to an adaptor.
I think anything with teflon would be ideal because the solvent is fed to the dispenser thru teflon tubes. The problem started when a need arise to use vacuum valves to suck away some residue.
Thankyou
Best Regards
___________
For part of our test system, we need to measure water level inside a chamber, which is under vacuum. We were successfully using one of these by...
112
28,190
Good afternoon all, does anyone recommend any coolant vacuum filter pumps to clean out tanks and get all the sludge and chips out of a...
2,985
Hello guys, how do you clean dust in PLC cabinets? Do you use industrial vacuum cleaners, compressed air maybe or something other? In most...
1,694
Hello, If you need to dump the air to allow someone to enter the cell, how do you handle situations where the vacuum is still holding something...
2,674
We got a quote from a vendor of some chlorine equipment but it is pretty expensive. ($525) It appears to be a UE brand vacuum switch with an...
2,203
