Output module MDL 940 GE funac
jcp
Feb 2010
Multan
369
Hi friends;
i use MDL 940 discreat output module with CPU 352 GE Funac 90-30 series.
The circuit breaker which suuply the 24 v dc to the module trip after some time while the LEDs on the module show correctly which output bit is ON and OFF. I check the wiring there is no short circuit found.
How can i check the module is it healthy and faulty.
According to the documentation i jumper Terminal number 1,6,11 and 15 and supply 24V dc. Other remainning terminal drive the relays and solonieds.
Please help me
Regards
If you've wired it correctly, then probably the sum of the loads on the active outputs exceeds the rating of the breaker. The module does not draw any power from the supply connected to the faceplate terminals. It gets its power from the backplane.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
370
I have run into a problem with my first time installing a 2080-OF2 module on a Micro820 and have a hunch that the module itself - brand new out of...
933
Hello, I am trying to streamline an AOI that will get module/controller statuses from ethernet IO tree. Everythings fine, however, does anyone...
1,558
Hello everyone, I am having issues with an output module connected to my 5069-L306ER PLC. The modules I have connected are a 5069-IA16 in slot 1...
706
I have a system with a 1769-OF4CI that sends signals to I to P devices that drive control valves. Recently I ran into an issue with one of the...
2,310
