Output to solenoid
Prayder
Jun 2014
Arkansas
254
I have an output that goes to an air solenoid and when the output fires... it fires twice in rapid succession. Not sure what would cause it to happen... any ideas?
Can you be sure that the PLC code isn't doing the double firing? Maybe throw a quick diagnostic rung in there with a counter on the output, see if it counts up in ones or twos.
If you can eliminate that, I would be checking on the rating of the solenoid and the rating of the output. The solenoid will have a large inrush current, and your PLC output may be current limited - perhaps the output is throwing everything it has at the solenoid to try and bring it in, then limiting and turning off for a split second, then coming back on and this time making it the rest of the way to saturating the coil so that the current drops back to a manageable level. I never ever drive a solenoid directly from an output, I always use an interface relay for this reason...
What PLC and output card are you using?
+1 For a quick troubleshooting rung, as well as adding a relay between the output and the solenoid. We have burnt up quite a few output cards wired directly to solenoids.
Ice cube relays, or solenoid driver relays would work.
I use these here almost exclusively now, high density, low cost, and easy to replace the individual relays if they ever fail. Haven't had any fail though in several years.
Make sure that the coil is not double addressed. Ive seen this happen before when there were two coils on the same address. One was off the same time the other was on. On the program it was constantly flipping because of the scan cycles changing it over and over. But it was on a DC light. I'm thinking the inductance is keeping that coil on after the second fire. Just a thought.
Hi Experts! I'm trying to control a solenoid valve (don't have part number, but I've been told its a 24V DC 30 watt coil) with a PLC output card...
6,630
I'm replacing a 20 some year old PLC with 1A rated triac outputs driving 120v solenoid valves that are rated at .3A Holding Current (all i could...
1,274
Hi, ive recently just started studying Plcs as a topic within my engineering course. and im finding it extremely hard to find information about...
5,400
I have an application using a MicroLogix 1200 that requires a pneumatic valve to be toggled on/of once per second for 5 minutes each hour. This...
2,721
Hey all, Here is the question. I have a IDEC FC5a-D16RK1 PLC which will be controlling three MAC valves (two series 52 and one series 56). I am...
3,659
