PLC output to solenoid valve.
colehan
Aug 2013
Grand Junction
Hey all,
Here is the question. I have a IDEC FC5a-D16RK1 PLC which will be controlling three MAC valves (two series 52 and one series 56).
I am planning on running two of the valves with the two transistor outputs on the PLC and the third valve with a relay output, since the PLC only has two transistor outputs.
After reading some forums on this site I am a little worried about controlling the two valves with the transistor outputs.
Specs on the PLC: 24VDC with 6x relay outputs and 2x transistor sink outputs. It specifies a max inrush current of 50A but does not specify anything for max current of the transistor outputs (or at least nothing that I see)
The valves are 24VDC (5.3W) solenoid valves. If I am calculating this right then the current for the valve is .221A? The valves however will be operating at fairly high frequencies (up to 10Hz).
What I am concerned about is burning up the transistor outputs. Would it be more prudent to run all three valves off relay outputs? Or with such a low current should I not be concerned?
Thanks,
Cole
I'm replacing a 20 some year old PLC with 1A rated triac outputs driving 120v solenoid valves that are rated at .3A Holding Current (all i could...
1,273
Hi, ive recently just started studying Plcs as a topic within my engineering course. and im finding it extremely hard to find information about...
5,398
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
123
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
246
Hello, the PLC in question is 1769-L30ER. I have a local 4-20mA Analog Output module (1769-OF4CI), and also a remote ethernet PointIO analog...
406
