Secpcb
= but are you a believer of a interposing relay just to run a indicator?
I would say unless there is a real need, an added relay would just be added costs for the relay, socket, wiring, wire labels, labor & panel space used.
Just wanted to know some thoughts/experiences on using PLC outputs to directly control panel indicators (lamps). I have a machine that I noticed used a icecube-style relay (24vdc I believe) to control a couple of indicators via a separate relay, just for lamp testing. A simple lamp test rung is within the program that does this. This particular machine is using a SLC502. But I've also seen this method used on a micrologic 1400.
For solenoids, contactors, and the like are self-explanatory. I just wasn't too sure if it was "good practice" to use relays for indicators as well, or just a waste of time and money.
Hi Liam, could you please increase my knowledge by explain how a resistant load has in inrush current?.
radrast, thank you for supplying some commonsense to this discussion. Interposing relays for indication lamps?, sounds like l had done a good sales job when l used to be a sales rep. But l wouldn't have done that either.
I have seen many lamp-test circuits on control panels, and usually 2 functions are required of each lamp: Normal, where some process switch or signal operates the lamp, and Test, where all lamps are switched to a power source when a Lamp Test button is pressed. All lamps cannot be wired together for testing, without some type of switching arrangement, otherwise they would all go on/off together all the time. Now what is the simplest way to create those 2 separate functions?Your machine may have been wired this way for the sole purpose of lamp testing.
