overwriting tags in RSView
JM_2.0
May 2006
Deep South
Hi guys, wondering if anyone can help me
I have a shell display, which loads a paramter file when opened, depending which option has been selected from a previous screen. What i am then needing to do is overwrite a tag with the value of another tag from the parameter file when a button is pressed. I have tried using a macro button, and creating a macro that copies the parameter into the tag. eg macro tag1 = #5. But the macro does not like the expression #5 and comes up with an error when the macro button is then pressed. Can this be done, or is there a better way of doing it?
Am using RSView studio ME
appreciate any help.
To put this another way, ideally what i'd like to be able to achieve is use a momentary push button to perform an expression. ie when the button is pressed, the value from parameter #5 gets written into the data register on the plc ( another tag ). Seems simple, but i just cant find a way to do it. I take it expressions cant be done with push buttons from what ive found so far?
thanks guys.
In my program my program tags largely exist in a couple of a data blocks. There are a number of tags in there that the operator may need to get...
10,730
Hello, I'm quite new with using FactoryTalk View Studio. I am currently using FactoryTalk View Studio 13.00 and creating a runtime file for an...
985
In the Allen Bradley alternate reality program logic and program data are linked together. Is it possible to update a Micro Logix program with out...
4,474
Hey guys, I have a client that is running Lookout as their HMI, and they have ancient Scadapacks out in the field. They had me program a spare...
1,171
My project requires that a pop up map pass a number or display a numeric display . While also someone should be able to enter the map number...
1,932
