Numeric Input Overwriting
earlgray
May 2016
Michigan
My project requires that a pop up map pass a number or display a numeric display . While also someone should be able to enter the map number into a keypad and the number display. It basically two different ways to get to the same result. "click the map and get the number or type it in"
Here is the problem. When I type the number into the keypad that number overwrites my essential map value number. I understand it is because I am using the same tag in every location. How would I go about fixing this problem ?
/sigh.
Software?
What do you mean the "Same tag in every location" ?
If you have the same tag everywhere, then everything will have the same number displayed.
Yes it the same project . I am still using Factorytalk ME.
When using the map , numeric input and numeric display I used all the same connection tags. That is the reason why I am having a overwriting issue.
Try doing as i said, use two tags. One for inputting & one used for display
I'm guessing this is homework right?
Hi all, First time poster here... until a year ago my ladder logic exposure was at a GM assembly plant in the early 80's, all on D size paper...
4,769
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
101
Hi I'm working in Studio 5000 View Designer V9. The HMI panel im currently using is a 5510, whit physical buttons and functions keys on both side...
183
Hey, within FactoryTalk ME I have this numeric input enable button and it is not working. On the HMI, I see the button and the label but when I...
522
For the project I'm doing, the operator has to enter a string of 7 alphanumeric characters. This represents the unique part number. For now, the...
19
2,417
