Lisa3003Lisa
Hey, within FactoryTalk ME I have this numeric input enable button and it is not working. On the HMI, I see the button and the label but when I tap on it the keypad does not pop-up.
I checked the button's properties, and the Keypad is selected within the menu. Also, the tag I use on the PLC end is a read/write tag. Within the connections tab I use the following tag for my value: {[CasePacker]ProductCodes[000].Conveyors.VFD_AccelerationConveyor_Speed}.
Also, I use tags for my min and max value, that check box is marked and the tags are working for other buttons.
I don't know why it is not working as all the other buttons with the same properties do work.
