Good Morning ,
I'm trying to use a Numeric Input Enable in a FactoryTalk ME application.
I have a REAL ( Data Type ) that I would like to change , so I set that tag up in the "Connections" tab. I then went into the Label tab , and inserted a variable so that the operator can see the change.
I thought I had everything right . Test ran the application , and when I enter in the keyboard the new number , in the Compactlogix program that real tag never changes . But when I went in the program , and I changed the REAL tag to 70 from 100 , the change showed up on the label ,
That tells me that there is something in the " Connection Tab " that I may be doing wrong. I can't imagine that , because it is just a tag link .
Any thoughts ,
Any thoughts ,
