FactoryTalk View ME numeric input enable/decimal
darknesspix
Mar 2023
Thailand
I'm using numeric input enable link tag to PLC DINT type. What I want is for the example in the panel view user will input 350.568 (and shown on panel view as 350.568)then tag in PLC will get 350568
Note:In the label/Caption : Number of digit=6, decimal places=3
Numeric : Fixed position,Stripped value, Degit after decimal=3
After input 350.568 in the pop-keypad but the nuneric missing the decimal.
Please kindly help me, thank you in advance.
I'm working on converting an old PanelBuilder 1200 HMI application into FactoryTalk View ME. The PLC was an old SLC 5/02 with a scanner card for...
1,107
Good Afternoon , I have an older Panelview Plus and do not have the application . I'm in the process of re-doing the HMI application from...
3,911
Good Morning , I'm trying to use a Numeric Input Enable in a FactoryTalk ME application. I have a REAL ( Data Type ) that I would like to...
7,180
Hi all, I'm working on a program with a numeric display field which seems to be capped by a minimum and maximum. This isn't a typical numeric...
3,295
Hi, can anyone help me? I am new to Factorytalk, but I have used other SCADA before. All I want to do is have setpoints on the panel which change...
8,680
