View Designer Numeric input
robsjo
Mar 2024
The north
Hi
I'm working in Studio 5000 View Designer V9.
The HMI panel im currently using is a 5510, whit physical buttons and functions keys on both side of the screen (L1-6 and R1-6)
I have no problem setting a bool bit in the PLC or changing screen.
But i would like to interact whit an Numeric input field. so that the numerical keyboard opens.
but i have no success whit that.
Is there a way to do that or is this a limitation from the software.
Thanks in advance
This is V8. I don't know if they changed anything in V9.
Go to Common Controls, lower left pane, and double click on Numeric Input. It should pop it on your screen someplace.
Then, you can click on the Icon and it will open up the right Properties pane.
In General, you add your tag in Value. It can be a Real or Int of some form.
You can change appearance, if you like.
In Numeric field, set where your decimal place is, If you are using one.
In Input, Set the limits of the Input Value you want from this.
Position and size are just that, adjust as needed.
If you need security for this item, then play with this option.
In this example, the tag is a Real.
Once you press the Icon on the screen, it opens up a really crappy (small) Numeric Keypad.
Welcome to the PLCTalk forum community, robsjo !
I think you might be asking about how to use one of the hardware Function Keys to launch the "Numeric Keypad" for a specific Numeric Input object, so the operator can enter a value using the hardware numeric keypad.
To my knowledge there is no current way to do that. Users always select and launch the Numeric Keypad by touching the object onscreen.
I have not used the Keypad-equipped PanelView 5000's yet, so I may be missing some understanding of how the hardware keypad interacts with Numeric Input objects.
@Ken Roach
Hi, Yes it's exactly what i want to do.
Thanks then i do not have to look fore an solution, and explain for the costumer way it's not possible.
Hoppe Rockwell fix an update for this, can't se an reason way this shouldn't be a funktion all ready.
Question for those who are in the know how Studio 5000 works/compiles under the hood. The laptop that was supplied to me is now full with no...
556
I'm using Studio 5000 View Designer 7.01 and I'm trying to make a generic popup with bindings to properties or aliases. Basic aliases by right...
441
Hello, We are beginning to use the View Designer software for the newer Panelview 5500 and 5300 HMIs. I one we are starting with is the 5300 10"...
1,203
I am trying to reduce the number of values behind the decimal point on the HMI. The values it is reading are "REAL" values from the PLC. I am...
1,109
Hi All I have been using Factory talk view the last year or so to do panel view software and visualization for projects. I am now doing one on...
508
