Bering C Sparky
Question for those who are in the know how Studio 5000 works/compiles under the hood.
The laptop that was supplied to me is now full with no memory available. I am not even able to open an upload from a small PLC in the plant.
I have already purchased 1 TB of memory to install in the laptop but that will not happen until after this fishing season is over. So for now I am deleting some of the applications that I use the least to create some space so the laptop is at least useable again.
I just deleted Studio 5000 Logix Designer V32 which freed up >500 MB
But I see there are also 3 versions of Studio 5000 Designer showing in installed apps.
Do I need 3 versions or can I delete 2 of them?
I am assuming each version was installed at the time I installed the separate 3 versions of Studio 5000 Logix Designer (32, 33 & 34) since I did not install these as a separate download myself.
If that is the case do different versions of Studio 5000 Logix Designer need different versions of Studio 5000 View Designer to function? Or can I keep one version and delete the rest? And if View Designer is used with/installed with each version of Studio 5000 Logix Designer separately, why was one of these not uninstalled at the same time I uninstalled V32?
I am reading on the subject now, but if those already in the know could shed some light I would appreciate it.
