P&ID . Help for an interview
bornwild
May 2010
Riyadh
429
Hello
I just received a call for an interview .I am just a fresher with two years of xp. My work mostly revolves around automation not much of instrumentation. Anyways they need a fresher for their company. First thing I was asked is Do you know how to read P n I diagarms Actually I just know some basics.But is it that hard or say important. Could this be learnt 2 3 days time since I have interview coming up .Please advice. What sort of questions can I expect.? Just googling and try to read every damn book on P and I lol.
I'm not an expert, but I suggest you to learn and memorize the most common symbols and to try to understand a few basic examples you can find on internet.
The P n I diagram is very important for design work in instrumentation. With a properly developed PnI you have probably 85% of the design requirements for each instrumentation loop. It tells you what you are measuring or controlling from the tag number, whether the instrument is in the field or a control center etc, whether the loop is say electronic or pneumatic, whether it PLC / DCS connected, line size and probable control valve body size, and more. So you should get to know your plant PnI diagrams well. In addition you should be familiar with your instrument index and your engineering standards for your factory.
"It's "P&I". "Process and Instrumentation". (add the "D" if you want.)"
I new that PnI was the wrong term but did not initially want to be too picky but as you brought it up it depends upon which part of the World you live in and which organisation / company in which you work. I have seen ELD (Engineering Line Diagram), PEF(Process Engineering Flowscheme) and of course P & ID. Not everyone uses the ISA standards.
What is the maximum integer unit for analog input of siemens 300 plc? pls help thank u in advance.
3,961
Hi Buddy's, I am a software developer. I have worked with embedded systems before 3 years. I need help regarding an interview which I will...
2,840
Hi, I have an Interview next week regarding entry level PLC programming. Can anyone tell me what kind of questions i should be expecting i would...
17
10,407
I HAVE APPLIED FOR JOB WITH PLC EXP. I DONOT HAVE PLC EXP.BUT HAVE TAKEN 'INDUSTRIAL AUTOMATION' COURSE I LEARNED ALLENBRADLEY, SIEMENS, MODICON...
6,597
Hi Engineers, Please help - I have to attend an interview with a company that is mainly into material handling and packaging. It is at a very...
3,805
