Panal View Plus 1500 historian trends
arifbalti
Oct 2017
Pakistan
Hi everyone,
i created historian trends, which is working good. Now, is there any way to go to any direct date in past instead of moving left/ moving right button?
i have to press too many times the "moving left/right button" to see the past values.
Is there any method from which i just need to enter the desired date and time of past to see past values?
Thanks u all,:sleep:
We have several Panal View 550s and the screens are getting very foggy and hard to read from glare from the shop lights. Is there a way to repair...
2,436
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
135
130
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
