Panel Builder 32 application "Tag Address" missing
Adam303
Aug 2009
Chicago
587
Hello all
I’m working on coverting a application from PV Standard to Plus, when I open the .PBA file and click on any of objects that write/read data from PLC all I end up with is the “Tag Name” under tag edit, no “Node Name” “Tag Edit” info is available.
Also under “Tools” “Tag Count” yields no information. The PV is standard 600 touch/key and is communicating over DH+ with a 5/04.
All the previous applications I converted would have an address listed under “Tag Address”. Anyone ran issue of this sort in the past.
@rdrast
There is not since this is a Panel Builder application.
But you need one in the PV+ application; For PanelBuilder I don't know why the node would be blank, unless the communications settings are messed up. You shouldn't need to use projects to properly specify the comms settings, those are helpful if you have say 10 panelviews looking at different items on the same host PLC.
IMHO, the conversion software is essentially worthless. I've always just started from scratch when doing a conversion like this.
Does anyone know where I could download panel builder 32 for old rockwell HMI's? Our supplier is no help and we are struggling to find the...
902
When using Panel Builder 32 I am adding a tag and the array size seems to default to 0 on floats and integers. I am wondering if this will...
1,132
I just finished making my 3rd service call to a large machine shop, troubleshooting PLC issues. I can see that none of the PLC or HMI programs are...
3,054
Hey guys new here, I've been googling and looking for a few days now and cant seem to find a solution. I'm looking for some program that i could...
1,189
Hi all, Is it possible to download the ABB Panel Builder 600 design software anywhere for free (but legal)? I am working on a job for which the...
7,533
