Panel View 1250 Plus Back Light
Saturn_Europa
May 2016
USA
58
I have a Panelview 1250 Plus that has been exposed to the the sun for 3 years. Its a little dim. I called tech support and they told me to replace the back light. I called my supplier and the back light is obsolete. They said I would have to change out the display. Its only $4,000!!! For a new LED display. Ill stick with the old school displays if I can.
CAT: number for the damaged display is 2711P-RDT12C series C
I found one from an online store for $1000
I found a back light on ebay for around $400
CAT: number 2711P-RL12C2
Looking for some advice. Replace the whole display or just the back light. I am not sure if its UV damage or not.
You might find the touchscreen has changed colour over time as well; from clear to a haze or yellow.
The touchscreen is a poly material on top of the glass LCD. UV light can cause it to change colour (crack) over time. So, if you change the backlight and it still looks hazed or dim then it could be that touchscreen material.
Bad news is, there is no way to replace that. You would need to replace the entire display module.
Hello, I recently installed an **** Flexy 201 so we could monitor our PLCs (one SLC 500 and one Control Logix) remotely under a VPN. One of the...
5,139
I had recently repaired a panelview plus 1250. the older firmware version of panelview was 5.00.04.55 (CPR 9). The repaired panelview came with a...
4,748
So I downloaded this .fup file from the rockwell automation firmware page, but have no clue what to do with it. Should I put it in a USB and plug...
4,582
Dear All i face a problem which is as follows :- for PV1250 the error 40 EXE , the error said it maybe firmware or internal compact flash or...
2,950
Hello every body, i have comunication problem with HMI panel view plus 1250 and cpu 1769L35E . i explain what i did : i made HMI project with...
1,954
