Panel view 1400e - - remote access
Hi experts,
Any possible to access the panel view from remote place - If yes ,please tell me the procedure.
Yes.
Depends on what type of access that you want and what you mean by "remote place" If you want to be able to program the panelview from afar, I would look into a serial to ethernet converter to get it onto a network with access where you need it.
If you want to see and operate the screens from afar, you are out of luck. The Panelview classics don't allow for remote access. You could replace that PV1400e with a new Panelview Plus and use the viewpoint feature for remote access with a web browser.
Hi jimbo,
We want to monitor the alarm status of the machine. because sometime operators said that machine down ,but when we go there , nothing was abnormal. Now, we are downloading the alarm history from panel view, only that we suspect the operators telling lie. Is that possible to always monitor the alarm/error status online from afar. we dont want to access/operate that panel view. this is same like a surveillance.
thanks
I saw a "poor man's" SCADA system once where the system operator pointed a web cam at the screen so he could check it from home.
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,715
I'm having a problem with my 1400e panel view communicating with A 5/04 PLC. I switched the program key in back of the 1400e to d/l the pvc. file...
2,371
Hi all, We are using Panel view 1400e Cat# 2711-K14C6.We have faced problem of screen going blank and when we checked t he unit and replaced the...
2,245
I recently had to revisit some old PanelView E screens to make some program changes. The program on my laptop worked fine (PanelBuilder 1400e, v...
1,957
I am new to PLC's and am trying to brighten the screen on my 1400e, I have used the little knobs at the back of the screen but the purple numbers...
3,860
