Panel View 900 only startup with white screen
Nov 2008
Rochester
Hi i have an Panel View 900 screen 2711-K9C8L1 , Firmware 4.00
After power ON the only thing i can see is a sharp white screen (seems like the backlight works) , is there anything i can test to solve this issue before i need to send it back for repair?. Have checked terminal behind the hinges and all seems to be connected correct still.
Any suggestions are appreciated
JJ
Welcome to the forum!
Do you have communications to the PV? Can you download to it?
If not, have you attempted a factory reset? I don't know the process on the older panelviews, but the PV+ can be reset to factory state and then have the firmware re-flashed.
Might be worth googling to see if you can find a procedure to attempt that on this model.
Found this procedure referenced on another thread here on the forum:
In order to reset a standard keypad PanelView to its factory default settings:
a) Reboot the unit.
b) As soon as self test number 32 is reached, press the lower left most key (i.e. F9 in the PanelView 1000, or F1 in the PanelView 300 micro) while simultaneously pressing the upper right most key on the front of the unit (i.e. the number 9 in PanelView 1000, or the "UP" arrow in the PanelView 300 micro).
Was on this thread:
http://www.plctalk.net/qanda/showthread.php?t=100708
Hi and thanks Logan for a quick answer, really appreciate that sir.
i tried all of this and will see if i can communicate with unit , will use RS232 straight cable to printer port/download/upload .
hope i can communicate with unit, so i can troubleshoot more.
problem i have is i cannot see anything on the display constant white screen only, so nothing else can be seen
I tried reboot do default settings nothing change, same thing with reset
thanks again .
Hi,I have got a panelview 900,the green light which indicate connection has stopped flashing and thefore connection between hmi and plc hast...
2,396
I'm trying to talk to a Ab 900 Panel View thru a AB 5/03. I'm talking to the 5/03 via RS232(Channel 0) but can't see the Panel View connected to...
5,599
Are there any restrictions on what memory card can be used on the PV900 2711-T9A5. I am trying to use a Dazzle; 4 in 1 PCMCIA Digital Media...
4,321
I am currently trying to run my Rslink,s thru a panel view 900 to a AB plc 5/02. Using only a serial cable with RS 232 connections then a serial...
4,940
I have the below Panelview in a gas plant. ALLEN BRADLEY PANEL VIEW 900 PART NO: 2711-K9A8L1 GRAY PAD WITH DH+ COMM & RS-232 PRINTER...
4,525
