Panel view compact runtime error
suvro2012
May 2012
Dhaka
23
hi all
I design a program in Controller L35E and Panel View Plus 600 and that program works fine and able to communicate. But the same program i change the controller compactLogix L16ER-BB1B with Panel view Plus compact. Now i am not able to communicate. when i create runtime file its shows warning ::"The system has detected that a device type that was not supported in the requested version is referenced by a shortcut. If the system upon which this project is to be run has received a patch that adds support for this device type, then this situation will not cause any problems. Otherwise runtime errors will be detected and logged by the target system when it attempts to communicate to that device :: " I dont understand the problem . Please help
You CompactLogix L16ER-BB1B PLC will not be able to communicate with your PanelView-Plus Compact. Possibly you could add a "patch" program that allows the L16ER-BB1B to communicate with that specific PanelView.
Dear expert /Group members Good day to your Does anyone have this problem? Problem explanation as below :- Thanks in advance
1,049
i done this many times but i dont know why this is happening. i have designing and configuring a panel view plus compact 600 hmi and i have...
1,904
having problems at work. power outage and everything back up except one machine. has compact logic and a panelview 1000. keep getting a write...
1,977
I have a problem with panel view plus "2711", the application is running but all values are missing"XXX", I ahve replaced the internal CF with...
5,176
Dear All. My new project for Truck loading System(Oil terminal) with ten Loading Arm. I want to use ten PanelView for ten loading arm( start, stop...
3,561
