Panel View error
dcurtis
Sep 2012
Michigan
Just wondering if anyone knows what "60 Error" means on a panelView 600. (the black bodied one) I got one sent back to me and I can't make the error come in here. 60 is not listed as an error in the help files.
See pdf
I don't know what you could do about it though. Call the people who repaired it I guess.
No one has repaired it, they want me to (I think). I can't make it do anything wrong...yet.
Thanks for that info Mickey.
Error 60 is a corrupt application error. Specifically, it means "CPU Could Not Execute Code".
It appears at startup, with a message in four languages: "ERROR! FEHLER! ERREUR! ERRORE!"
It's in the User Manual, 2711-UM014, page 268.
This is going to be *.PVA application file dependent; you won't see it with a test application in the terminal, and you might not see it if the original application isn't connected to a PLC attempting to process PLC data.
Hello, I was wondering if any of you have came across this issue I am having. I can download to a 12" IC754VSI2CTD-KJ with my old Windows 7 laptop...
1,938
Hi I have a problem described below: I have a panelview application which is actually running on a 2711R-T4T panelview 800 which I call the "old"...
3,563
Hi Friends, I'm getting several same error messages; ''Timed out Reading F28:9 from MircoLogix at 192. 168.0 30'' from a Panel View Plus 700...
2,036
I am trying to hook up a GE QuickPanel View to an Allen Bradley MicroLogix 1000 via serial. Once I load the runtime into the View I get the...
4,496
Hello guys, im in big trouble, a few days ago turning up a machine we came acros this screen, its a Panel View 600 btw. Checking the...
4,917
