Panel View SE Edition
Jul 2015
Auckland
Hi
I have always been using ME Edition but for this particular site I am using SE for the first time.
The client require a stand alone version (local) and a distributed version.
I have developed a stand alone version and that is working fine. Now I am having trouble converting it to a distributed version. Essentially I need to setup a client that is running distributed version and an HMI server on the client's server computer.
Any help or pointers will be welcomed!!
If you are using SE distributed, why bother with SE Station, which it sounds like you are?
Anyway, Open you "Local" application, export all of the tags to CSV.
Open the "Distributed" application, create an application, then import the CSV tag file.
Copy everything from the local application GFX folder to the Distributed GFX folder. In Studio for the "Distributed" application, right click on the displays icon, and add each graphic into the application. Do this with everything you need, macros, events, whatever.
Good luck, SE is the bottom of the barrel by a long way for HMI systems.
I'm looking to implement some complex recipes within a GE Quickpanel and noticed in the help files that it's possible to use equations within the...
2,243
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
233
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
301
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
147
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
170
