Panelbuilder 1400e to PVP7 ASCII/String Display
ballack
Jul 2013
TX
30
Hello gentlemen,
A few days ago I was tasked with converting an old panelview 1400e to a panelview plus 7 application.
Everything went well except for the string displays.
The ASCII displays in the old PV point to a set of FLOAT addresses in the PLC, and they in fact display things like recipe names, etc.
Pointing to the same addresses from the newly developed PVP7 just displays the number stored in that address. Is there an easy way to fix or work around this?
Here's an example of the data that I have in the PLC:
F8[56] = 1.46696165e-019
F8[57] = 13.570386
F8[58] = 1.45800261e-010
F8[59] = 1.35701254e-019
F8[60] = 1.35631564e-019
The old PV displays something like: "02 - MAYO / 50"
Let me know if this info is enough.
Programmers did a lot of weird stuff back in the PLC-5 and PanelView Plus days.
Are you also upgrading the controller, or are you still using a PLC-5 ?
The programmer is packing ASCII characters into Floating Point registers. I'm not sure why they are doing that instead of using Integers.
If you copy those 32-bit Floating Point values into a register where you can see their values in hex, you would see this:
Code:
20 2D 30 32
41 59 20 4D
2F 20 4F 20
20 20 35 30
20 20 20 20
If you view those bytes as ASCII characters, they come out to
- 0 2
AY M
/ O
50
I don't think there's a way to point FactoryTalk View at an array of REAL values and have it display them as a string. You're probably going to have to put them into an actual String datatype.
There may be some tricks and compatibility things I'm forgetting; I happily did my last PanelView 1400e migration project at least ten years ago.
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
281
I am trying to make a couple of changes to a PV 1400e project. I have to add a couple of multistate indicators. Adding the graphics went fine but...
1,201
I am running Windows XP Pro SP 3. Panelbuilder 1400e used to work on this machine, but now it doesn't. I suspect this is due to a recent Windows...
1,327
Hi I just migrated a program from panelbuilder 1400e to factorytalk view me, everything seems fine except the alarms. The problem is the...
3,486
Looking to for a copy or a demo of Panelbuilder 1400e to do an upgrade. Can anyone help me out? From what I read through out I can use this to...
2,397
