Panelbuilder 1400e
stevengaa
Dec 2007
Milwaukee, WI
Looking to for a copy or a demo of Panelbuilder 1400e to do an upgrade. Can anyone help me out? From what I read through out I can use this to upgrade the old 1200 unit which used the dos base panelbuilder, and from there once I put into the 1400e format I can then upgrade that to RSView for the new PanelView Plus. I have three of these old 1200 units which need to be upgraded. Thanks in advance for your help.
If i read your post correct you want to upgrade 1200 apps to 1400'e so you can then upgarde to PV+ apps ?
If so just post the 1200 apps here and me or some other nice chap (lots of them here) will post the 1400e file for you to upgrade to PV+
I'm in need of one more file to be converted over to the 1400e. If someone could be of help once again I would really appreciate it.
Thanks Once Again To All.
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
293
Hello gentlemen, A few days ago I was tasked with converting an old panelview 1400e to a panelview plus 7 application. Everything went well except...
1,320
I am trying to make a couple of changes to a PV 1400e project. I have to add a couple of multistate indicators. Adding the graphics went fine but...
1,204
I am running Windows XP Pro SP 3. Panelbuilder 1400e used to work on this machine, but now it doesn't. I suspect this is due to a recent Windows...
1,328
Hi I just migrated a program from panelbuilder 1400e to factorytalk view me, everything seems fine except the alarms. The problem is the...
3,489
