blueyedpeter
Before i start today i will apologise for the last post as it was very messy .
I will keep it short i am having trouble with the panelbuilder 32 software and the communication ports and there set up.
The micro300 panelview i have is set up for Dh485 communications , and when i try to up load the program from the panelview terminal , the choice of comports is limited to only Df1 communication ports . And excludes the communication port that i need to use.
At the moment i am not sure how to make the software communicate in Dh485 the communication port is not listed because it is not a DF1 port.
I am able to configure rslinx and the 1747-uic driver properly and when i use rswho the terminal appears as node 2 and the workstation as node31 .
In tools and options in the panelbuilder software this is wear it appears that you select the default terminal set up but it appears not to work though .
And by the way thank you for the previous advice, night shift tends to aggravate things a little but thanks again.
