Panelbuilder 32 Error 2272
donl517
Dec 2005
Michigan
127
Error (2272)- PCCCSTS10, illegal command or format, including an old address.
OK here's the scoop: I am making some requested changes for a customer. Not my program but hey it is a paying job. So I need to add 3 screens to a micro 300. They emailed me a copy of the program that is in their micro 300. I have made my revisions and had a micro 300 here I wanted to test it out on. However, I get the above error. This is a brand new unit right out of the box that I am trying to download to. He is using the DH485 protocol on the micro 300 as well as a micrologix 1500, so I was trying to stick with that for test purposes. He has several other devices that are communicating with the PLC so changing protocols is probably not a good idea. I am using revision 03.82.01 (Build 451) of Panelbuilder 32. Any suggestions? I could not find the error on AB's website.
Thanks,
Don
OK, Apparently no one knows what the problem is. However, I have the answer.
I talked to the AB rep this morning. Apparently there are 2 versions of the AB Micro 300. One is DF1 and the other DH485. The reason I could not download the program to my unit is because it is a DF1. I changed the protocol in the program and bingo! It downloaded fine.
I hope this helps someone else!
Thanks,
Don
Hello, anyone had a similar experience? A customer has an old panelview600, it is faulted, but is communicating and they desperately need to...
3,752
When trying to Upload from a Panelview 1000 I keep getting the following error message. Error [2158] DTL_E_DRIVER_NAME_INVALID Specified Driver...
2,919
Hi guys. I have a panelbuilder 32 application which is giving me the error above when I try to download. The error says that the write tag is...
5,895
Hi all - Does anyone know if there's a decent way to import alarm text into a Panelbuilder32 file (v. 3.82)? I've already typed it once & don't...
3,192
Hey guys. We have a couple of laptops that come up with the following error DBTemplate Copy Fail when trying to open a file. I have opened these...
5,986
