Panelbuilder Help
JGrissom
Dec 2013
colorado
18
Hi All,
Working on a SLC5/05 with two Panelview 600 using Panelbuilder32 (yuk!) and need to set on of 6 bits using buttons on a screen no problem right? I'm using Latch buttons with the same bit as a handshake and had two of them working but today I went back to add some imbedded variables to the buttons which seem to be working properly but now the buttons act like a momentary button. I press the button and as long as I hold the button the code responds properly but when released the bit is rest to zero. Anyone know what I'm doing wrong? Toggling the bit in the PLC works just fine and the buttons indicate properly.
Thanks!
JGrissom,
which version of panelbuilder 32 are you using?
the latest version is 3.83.01
i'm asking becaust a previous version had a bug in the software.
in regards to the bits, what are you doing with the handshake word? check to make sure you are using maintained buttons, check to see if the bits/ bit words are being cleared in the program. check to see if a copy, move, file fill is accessing the words by mistake.
are these bits the same on 2 or more of the pv terminals?
if so, they are interferring with the others.
regards,
james
Thanks James,
Version is 03.82.01 (Build 451). I think I figured out how to do this, it seems that the handshake bits I was using are immediately set so the buttons are turned back off as it looks like it is supposed to do (I think). I found away around this by creating handshake bits that only turn on when the button should no longer be selected...
Jim
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
292
Hello. Before I get chewed out, I did do a search on here for some SL505 passthru help. I noticed there was a small handful of information on...
3,578
Hi guys I have a question can I use a panelview 1000 on a compactlogix and use the tag names not bit addresses ?
1,617
Hello again. To get right to the point I have a Panelveiw 600. I want to create a screen and have a couple functions tied to a micrologix 1500. I...
2,741
Hi everybody! I recently found these forums and they have been a great help, you guys have got me through quite a bit! But, today I'm unable to...
3,644
