Donald.Blake
I am attempting to mix old with new. I have a 1400e HMI that is communicating to a plc5 via DH+. I need to set the HMI up to read some of its values from a 1756-L73 processor as well as continue reading some from the plc5. My thoughts are to just add a DH+ card to my clx, drop it on the network and map the tags in L73.
My current attempt has failed. I have my address of 1400e as 15, my plc5 address is 02, and my CLX DH+ card is 46.
I have my nodes setup in 1400e as plc5 enhanced with address 02, then clx is setup as plc5 enhanced as address 46. I have also tried setting my clx as logix 55xx with no luck.
The plc5 communicates fine. My clx mapping is setup as 24 file number - to "clx tag". I seem to have some incorrect setup somewhere but can't identify my issue. The 1400e shows an error when running application of "Remote station does not match the configured plc". Any thoughts?
