PanelBuilder32 Display Change
MJC
Mar 2011
ILL
125
Hi, I did quite a bit of searching around in the help files and manuals, can't quite find anything that can help me, so hopefully someone can.
I have a small project that runs a meat massager. It's cycle is based on time. Once the cycle completes I trigger a bit in the PLC (SLC 5/04). With this bit I'd like to call a screen change in the HMI, to notify the operator that the process has completed. From there I want the operator to touch the screen returning him to the previous screen that he/she was in.
Please shine some light.
Thank you.
Have a look under Aplication Settings at the Control Tags. There is a Screen Control Tag Setting there. Then put a Return Pushbutton on the Screen that you open to take you back to the original Screen.
Stu....
Make sure the register you use to control the screen change is reset to zero after
the screen change occurs. This will release control back to the operator.
Also for future referance, how can I know/read what screen the operator in is in?
I would use One Shot Instructions on the Data moves to the PV Screen Number.
If you look in the same Application Settings, there is a Status Tags Tab. One of them is for the Sreen Number.
Stu....
Instead of "Control Tags" open "Status Tags" to read the screen number.
See Picture below
Edit: sthompson types faster then I do.
What happens if the process never gets completed ?
You might just use a "EQU" to compare the screen status to 27 and then give control back to the operator.
Yes that's what I thought, Thank You
Mickey the process can be stoped via push button, if this happens an alarm message is triggered, and stored in the alarm list. The operator can pause the process at any given time, and in the event of fault such as overload trip the process is paused as well, and can be resumed by the operator if the fault is cleared/fixed
That was my point, if the process never gets completed ( your post #6) then you are stuck on screen 27. You need another method to reset the screen control.
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,486
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,097
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,645
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,272
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,615
