Panelbuilder32 to memory card
andy_1983
Mar 2018
uk
76
Is it possible to save a project in PB32 as a .PVA application, then save to a memory card and load into a PV550 or PV600?
From some searching it looks like I might be able to:
Format a <2Gb SD card into FAT16 form
Modify a PB32 application, and save as a .PVA file.
Put .PVA file onto SD card
Mount SD card in SD to PCMCIA adapter
Use Panelview 550 or 600 to read from card and load modified application
Anyone know if this will actually work?
I’ve got all the cables and UIC box to do this properly, but trying to work out a way of doing it that doesn’t involve using RSLinx
Andy
Many thanks for the info. I’ll pick up a compact flash card etc next week and have a go.
Thanks again
Andy
Something is wrong with PanelBuilder32 that is installed on my laptop. I’m running version 3.82.01; the latest one, direct from the website. I...
24
9,543
I've been trying to download a program to a PanelView 1000 terminal (not a PV+), and after it gets done "validating" it pops up an "Out of Memory"...
4,088
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,447
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,087
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,636
