Panelbuilder32 translation problem
I just had very similar experience. I successfully downloaded screens from one pc to PV600 using PanelBuilder32 and DF1 driver. Transferred screens file to another pc, made small changes and tried to re-download them to same PV600 over DH+ and got "out of memory" error, Tranlsation Failed. And this error occurred immediately after validation, before it even looked to the PV600, so I don't think the driver effects it.
I didn't think of it until I just read your post but 2nd pc has RS View Studio installed. Have you found a solution?
As a follow-up, I transferred the modified screens file back to original pc and it downloaded fine. It is not a real memory issue. At least with mine.
I got a translation error after deleting the address tag from the database while there was still an object referencing it. Strangely, I did not get a descriptive error "______not found in database" until I did a "save as" and tried to download the copy.
I'm hoping this is a simple one. I have a computer running XP SP2, with Panelbuilder 32 (v.3.70). I have a tiny change to make to the screen on a PV600. I have both original PBA file and was able to upload the PVA file. I can modify either and save as a PBA. But when I go to download it, I get a "out of memory" error, then a "translation failure" message. I assume this means it is failing to create the PVA.
If it helps, I also have RSLogix500 and RSView Studio.
Any Ideas?
panel builder is different than panel veiw
I had a simular problem some time ago & never got to the bottom of the problem
I was sure it was the Panelbuilder S/W as I had the same problem even without any mods, as I did not need to make any changes I used the download util. I even tried to re-install a number of times (even to the point of removing any refference in registry etc).
I had a new pc a few months ago (XP Prof same as before) & after installing all my software it has worked fine since.
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,455
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,089
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,638
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,266
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,610
