panelbuilder32
Teaked
Apr 2005
Hey anybody
i am working with a slc 5/05 and panelbuilder32 havent worked with this in a while. when validating my panel builder tags i get a error. (slot number of address does not match other tags) example O:12.0/0 i am assuming slot is 12 . iam trying to re-use a different project and not sure if i have configuration corrrect.
is there a way to change slot globally
thanks for any help
Rsdorans syntax is correct
I would do a find and replace see attached pdf which i think would work for you
Remember that on the PV and SLc's an Output can only be read and not written to (see pic)
What you are seeing is word addressing.
O:{Output}12{Slot Number}.0{Word Number}/0{Bit Number}
It should be valid for both the SLC and the Panelview
O:12.0/0 = O:12/0
O:12.1/0 = O:12/16
O:12.2/0 = O:12/32
Either format should work.
Dave
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,455
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,088
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,638
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,266
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,610
