PanelMate 1550K PM 1500 POWER SERIES
Larry w
May 2020
Woodville
I have a PanelMate 1550 which has gone into recovery mode.
I can't get it back to Serial transfer mode so I can download the software again.
Anyone have any idea's of how I can get this out of recovery mode?
Thank you in advance.
Larry
From what I understand if a PanelMate has a firmware corruption or something like that it will go into recovery mode. From what I have been able to find out is I need to get the Panelmate back into Serial transfer mode, reload the firmware, driver then the program.
I can't get the PanelMate back into serial transfer mode.
I've never encountered recovery mode myself. Looking through the documentation I have I came across a reference to touching the lower right hand corner of a touchscreen model while powering up to force it to come up in the serial transfer mode. That would appear to be the area where the recovery mode prompt is located. Have you tried touching the recovery mode prompt to see if that drives you to the transfer screen?
I did power it up and down with the two bottom buttons pushed in but no change at all.
This is not a touch screen. I just thought one of you guys may have had this happen to you and had a different way of getting it into serial transfer so I could load the firmware and program. I know these are old but out of all the ones I have had dealings with I like these the best.
Ok, so I gave it a go and tried the top two, top one and the third one, top and bottom one, almost every configuration I could think of but no change. I know this can be changed because a guy that worked here before did it for me but he is long gone.
Larry w
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
519
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,274
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,153
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,091
Does anyone know of a modern HMI that can use or convert a Panelmate PPS file?
1,030
