Panelmate 5000 offline mode
http://www.automation-interface.com/pdfs/100395.pdf
See page 11:
• To force a Keypad Unit with four control buttons into the Offline Mode, press the first and second control buttons simultaneously immediately on power up. Then select the Enter Serial Transfer Mode template or the Enter Network Transfer Mode template to enter the Transfer Mode.
• To force a Keypad Unit with five control buttons into the Offline Mode, press the second and third control button simultaneously immediately on power up. You can then select the Enter Serial Transfer Mode template or the Enter Network Transfer Mode template to enter the Transfer Mode.
To force a Touchscreen Unit into Offline Mode, press the lower right corner once the touchscreen controller diagnostics are completed. (If you press the lower right corner on the touchscreen before the touchscreen diagnostics are completed, you will receive an error.) You can then select the Enter Serial Transfer Mode template or the Enter Network Transfer Mode template to enter the Transfer Mode.
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
519
Good day All! I have been working on a PANELMATE POWER SERIES 5000 HMI, we have decided to replace it with a Delta HMI. The software was...
1,135
Good morning gentlemen! Attached is a PPS file from a Panelmate power series 5000 HMI. can someone help me with a print out of the pages...
1,445
I am attempting to communicate from a Eaton Panelmate Pro 5000 to an Allen Bradley PLC 5/30 processor on the DF1 serial port. This is a 9 pin to...
5,752
I am trying to set up communication between a panelmate 1700 and contrologix PLC using DH+. I have set-up the mapping in the processor and I...
2,029
