Panelmate to RS5000 mapping
da5coles
Mar 2006
WI
I am trying to set up communication between a panelmate 1700 and contrologix PLC using DH+. I have set-up the mapping in the processor and I updated the drivers in the PM but I am still not communicating? What am I missing?
How should the Panelmate know the Slot number of the PLC? You have to use the Gateway functionality of the 1756-DHRIO Card (configure in RsLinx)
Very good point, Klaus.
The 1756-DHRIO module can communicate with a ControlLogix CPU in any slot of the chassis if and only if the incoming message has routing information in it to designate the slot.
I expect that the PanelMate doesn't have that routing information in it's DH+ driver.
Fortunately, the default CPU slot number in the 1756-DHRIO is Slot 0, and most users place the CPU in Slot 0 just out of habit.
Test the DH+ communication with a PLC-5 or SLC-5/04 first, if you have the chance, then try to migrate it to the 1756-DHRIO and ControlLogix.
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
519
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,274
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,154
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,091
Does anyone know of a modern HMI that can use or convert a Panelmate PPS file?
1,030
