Panelmate, Canvas 3.3 and ControlLogix 5500
SLC_mofo
Oct 2008
BC
Hi Everyone
I have a 8" Panelmate and had to use Canvas software to design an HMI because apparently the original Panelmate software cannot read the arrays that exist in a ControlLogix 5500 PLC.
After spending hours on perfecting my design i find out that the Panelmate will not load the .ucf because it is incompatible!!
This only occurs on bootup and i can run the .ucf file manually but i need it to start automatically everytime the touchscreen resets.
Also is there an easy way to transfer the media library from one computer to another? I tried the export function but to no avail.
Any suggestions? Thanks in advance.
Canvas and Logix
I have done a large Logix application on Canvas and I learned a few tricks to save time.
First off an Panelmate ePro will be needed to run the Canvas application. The standard Panelmate doesn't support Canvas, and there is a special version of the ePro to run old Panelmate files.
The Media Library is bit difficult to work wit, but if you make a default directory that can be easily copied to the ePro, you will save yourself time later.
let me know if you need any more help.
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
519
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,274
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,154
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,091
Does anyone know of a modern HMI that can use or convert a Panelmate PPS file?
1,030
