Regarding Panelmate Configuration Editor 2.50.6.50b2 and the "References => Tags" function. This works well to replace tags as long as programmers have not already included the "Item Name" or PLC reference portion of the tag/expression, i.e. [PLC1,tagname].
Does anyone know of any methods to delete or replace the "Item Name" from existing expressions assigned to objects in the application (in bulk rather than one at at time)? i.e. remove "PLC1," from the expression [PLC1,tagname]
I've had success adding the "Item Name" using the "References => Tags" function, but have not been able to determine any reverse functionality.
Thanks in advance,
mjfergus
Thanks in advance,
mjfergus
