Panelmate to GE Fanuc 90-30 Com Cable
dwaller67
Nov 2008
TAMPA
Does anyone have the schematic for building a com cable to connect a Panelmate Power Pro 1775T to a Ge Fanuc 90-30 plc? I know I can purchase one, but this is for a pet project so I'm trying to keep costs down. Thanks.
If you're going to use the 15-pin port on the 90-30 power supply:
PanelMate 90-30
9-pin 15-pin
1----------11
6----------10
4----------13
9----------12
+-8
+-14
+-6
+-15
Be sure to specify RS485 (or is it RS422?) in the PanelMate port setup.
I've run into two issues regarding communications between PanelMates and GE Fanuc 90-30s. First, the PanelMate SNP protocol driver's default parity setting is "None", while the PLC's default setting is "Odd".
Second, older versions of the PanelMate SNP driver required a value to be entered for the SNP ID. In the PLC, the SNP ID defaults to a null value. Newer versions of the driver fixed this, and I'm not sure at which version it happened. If you encounter this problem, you will need to enter a non-blank value in the PLC's CPU configuration. Note that a value of zero is not the same as no value. I hope that by bringing up the second issue I haven't totally confused things.
I have a Fanuc 90-30 running a shear. The panelmate Board went bad and was replaced. I got the panelmate running but the Fanuc sends bad data to...
1,944
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
528
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,278
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,159
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,094
