Panelview 1000 communication
iggy
May 2007
FLORIDA
198
Hello,
I am having a problem with our panelview 1000 (ethernet, v4.2)
I have no problems getting the panelview to read tags from all our plc's except for one. They are all on the same network and can see them all in linx. The only difference is all the plc's are plc5 40e and the one I can not communicate with is a
plc5 60b with an ethernet side card. I am using Panelbuilder
v3.82.
I checked the communications and made sure the ip address was correct, even deleted it and tryed it again.
I also had to do some changes in a rsview project in the same room and have no problems seeing the tags.
Any advice greatly appreciated.
It turned out to be a very old version of the side card.
installed new card and reads tags now.
thanks again fuzzy
i am trying to communicate to my pv1000 by the rs232 port using rs linx which is not detecting the pv1000. please to assist me with this problem...
2,845
Hello All, We recently picked up a Panelview plus 1000 and are try to communicate to our existing PLC. I have inputted an IP address for the...
1,347
I have a system with two (2) Panelview 1000 terminals communicating to two (2) CompactLogix processors via Ethernet (all communicating with each...
4,793
Hello, I am pretty new to PLC control and am having a problem with a panelview 1000 HMI and need to replace it however i can't seem to be able...
5,268
I am having problems connecting to panelview 1000 using 2711NC13 and 9 pin to 25 pin converter... i used same setup parameters (Rslinx) to other...
3,413
