Panelview 1000 to 25 pin female communication port
bioplc
Jul 2005
tampa
97
I am having problems connecting to panelview 1000 using 2711NC13 and 9 pin to 25 pin converter...
i used same setup parameters (Rslinx) to other laptop with 9 pin serial port..it worked fine...am i missing something here???
Please help
From what you are saying it sounds line a new laptop with a 25 pin paralell port and no serial port, will not work if it is the printer/parallel port. If the panelview uses DF1 then you may be able to use a USB or pcmcia to serial adapter.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
141
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
215
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,139
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
452
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
904
