Panelview 1000 DH+ to SLC505
averellen
Jan 2004
Guelph
112
Is it possible to connect a panelview 1000 DH+'s serial port to a SLC505 serial port for communication?
Currently it is connected to a SLC504, but I have an OPC application controlling some aspects of the 504. I need some more speed, a 505 will get me a couple seconds. Update time of the panelview is unimportant.
I also have a ControlLogix RIO to ethernet gateway in the plant.
That is how the OPC connection is made to the current processor.
Is it possible to connect the 505 to the PV1000 through the gateway?
Adam
I believe on the DH+ models the Serial port is a "printer port" only. What is the actual model # of the PanelView?
Marty
That's what I was afraid of. I got that from the docs too. Just seeing if someone figured a fancy way around it.
Adam
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
154
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
237
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,159
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
459
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
915
