Panelview 1000 Freeze up
EWORD
Jul 2005
ALA
I am having problems with some of the icons freezing up on the panel view. The configuration consits of an AB panel view,a Fanuc Robot M-16iAL, AB SLC 500, and Device net. The inputs are functioning correctly I can monitor the stand alone computer running RSlogix and i can see the Photo eyes change states, But on two occassions I noticed several of the icons not updating to the panel view. Could this be a glitch in the Panel view or is something else going on.
Please check if you have terminator resistor in your network (if you are using RIO/DH+).
Besides that if you are using DH-485 protocol, I suggest you can change to DF-1 (we have similar experience).
Maybe you can also check if the temperature of the PV+ is too high, I notice PV+ operating temp is much higher than the PV, might due to heavy processing and harddisk inside the PV+ :)
Hope it helps.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
148
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
223
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,149
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
455
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
910
