PanelView 1000 interface to Mitsubishi A3 PLC: POSSIBLE???
Steak
May 2003
Does anyone know if you can interface a Mitsubishi A3 PLC to a Allen-Bradley PanelView 1000? If you can do it, let me know
STEAK
Rockwell has never been particularly interested in having PanelViews communicate with non-AB PLCs. I believe that the only non-AB protocols supported on PanelViews are Modbus and DeviceNet. If I'm mistaken, I'm sure someone will correct me.
So, if you can get a Modbus or DeviceNet interface for your Mitsubishi, then you can probably use the PanelView. Otherwise, there are several brands of HMI that can communicate with a broad range of PLCs, including Quick Panel, PanelMate, Maple Systems, and many many others.
I have no idea if it can be done with that particular plc or not BUT!
The Panelview can use all the AB default methods of communication..ie RS232C, DH485, DH+.
As was stated above they can be used with Modbus or Devicenet, they also will work with Controlnet, Ethernet and Profibus.
The manual for Standard Panelviews is http://www.ab.com/manuals/eoi/pdf/2711-um014c-en-p.pdf
User guide for Profibus DP is http://www.ab.com/manuals/eoi/pdf/2711-63.pdf
User guide for Modbus is http://www.ab.com/manuals/eoi/pdf/2711-69.pdf
Protocol Converter
You could put a protocol converter between the PLC and Panelview, such as an X-linx from mySST.com. Then the Panelview will "think" it's reading an Allen-Bradley PLC, while the Mitsubishi will "think" that requests are coming from whatever reads Mitsubishi PLCs.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
136
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
214
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,139
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
451
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
901
