PanelView 1000 (old PanelView32) Comm Prob
steveb55
Jul 2015
Indiana
Hi Guys...
Got an issue communicating with an old (unsupported) PanelView 1000. Tried both USB converter and actual RS232 port (yes, printer setting is disabled). Strange thing is... when doing an auto config via USB converter, it auto config's at 19200. What? The PV is set to 9600. Anyway, after the autoconfig the node can be seen, but when trying to download it chokes on the first step of trying to identify the PanelView. We have just tried deleting and reinstalling the serial port to make sure nothing is using it, but we cant try it for another couple hours.
As always... Thanks for any assist.
Steve
Communicating through the printer port. The first time I tried I used the same RS232 cable I use to communicate with the SLC 500s. If you made that same mistake then you need to buy or build a cable. I've seen something similar as far as the com speed goes on the printer port. The default comm is 9600 yet when I auto connect it says 19200. I don't understand why but it works for me.
Worst comes to worst get a PCMCIA card and transfer that way.
Please provide the complete catalog number of your Panelview.
Also tell us more about your USB to serial adapter (brand/model number)
Hi All! Is it possible to establish any remote access on PanelView Plus 2711P-T10C4D6 (logic module 2711P-RP6)? This panel is running WinCE 4.10...
1,866
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
144
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
220
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,142
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
453
